Windows Performance Monitor
Discussion in 'Ideas' started by quasar, Nov 24, 2015.
  1. quasar
    Sep 22, 2008
    We encountered a problem that windows performance monitor can not show active calls anymore.
    However, this function works under version 12.
    This function is really useful and helpful for us.
    Hope can be back soon! ;)
  2. AlexHeylin
    Nov 30, 2015
    44
    9
    You might like to vote this up so it gets some attention.
    http://www.3cx.com/forums/snmp-monitoring-43595.html
