Windows Server 2003 support
Discussion in '3CX Phone System - General' started by kent_heighton, Oct 19, 2007.
  1. kent_heighton
    Oct 19, 2007
    Does 3CX work on Windows 2003 Server 64 bit?
    Can it be deployed under MD Virtual Server 2003?
  2. weebnuts
    Sep 13, 2007
    37
    yes, I'm running it on Server 2003 64-bit, all running fine.
