Windows Server 2012 R2
Discussion in '3CX Phone System - General' started by dapersico, Feb 18, 2014.
  1. dapersico
    Feb 18, 2014
    Trying to install 3CX v12 on Windows Server 2012 R2 with IIS. It installs just fine but I cannot browse to the 3CX admin page. Is there any special install requirements or steps I need to take in order to get 3CX running on this platform?
    Thanks!
    Dwayne
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    If using I.E. Explorer, use the compatibility view settings under tools. You can also use Chrome and Mozilla.
  3. dapersico
    Feb 18, 2014
    Seems to be an IIS configuration issue not a browser issue. Chrome does not work either.
    HTTP Error 403.14 - Forbidden
    The Web server is configured to not list the contents of this directory.
    Dwayne
  4. dapersico
    Feb 18, 2014
    There is nothing really in the webroot directory.
    Detailed Error Information:
    Module DirectoryListingModule
    Notification ExecuteRequestHandler
    Handler StaticFile
    Error Code 0x00000000
    Requested URL http://localhost:5000/
    Physical Path C:\ProgramData\3CX\Data\Http\webroot
    Logon Method Anonymous
    Logon User Anonymous
  5. dapersico
    Feb 18, 2014
    Found the problem! 3CX v12 installer is incorrectly pointing to C:\ProgramData\3CX\Data\Http\webroot for its document directory in IIS. If I change it to C:\ProgramData\3CX\Data\Http\interface it seems to work.
    Now to see if everything else is working.
    Dwayne
