Windows Softphone Freezing After 15.5.0 Update
Discussion in '3CX Phone System - General' started by vizualpro, Nov 17, 2017.
  1. vizualpro
    Jul 9, 2016
    81
    13
    Did update for Enterprise v15.5, Update 2, Build 15.5.6354.2 last night and users were prompted to update the softphone this morning, everything seemed to be running as it should. In the last hour, two users have had the application hang and force them to restart it. Has anybody else experienced this issue?
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    873
    131
    Hi vizualpro,
    Not personally but my first thoughts are check and upgrade Windows updates and your .NET framework on the client PC's, then reboot and check again.
  3. vizualpro
    Jul 9, 2016
    81
    13
    I certainly appreciate the suggestion! The workstations are 100% up to date with windows updates as well as .NET 4.6.2. Users that are in CTI mode and utilizing the switchboard have no issues, but our staff who are on active calls on the soft-phone are having it freeze mid call since this update. As soon as the application hangs the call is dropped.
  4. eddv123
    Aug 15, 2017
    873
    131
    I noticed from your log it looks like you are using Windows 8. Although supported can I check are all the effected phones on Windows 8 ? could you try or confirm if you have tried with a different version of Windows ?
  5. vizualpro
    Jul 9, 2016
    81
    13
    Our workstations all run Windows 7 Pro SP1
  6. vizualpro
    Jul 9, 2016
    81
    13
    Update: I've reboot the end user computers as well as the server, problem persists. May end up having to roll back to the previous version this afternoon.
  7. eddv123
    Aug 15, 2017
    873
    131
    Hi vizualpro,
    The only other option if not done so already is removing the soft-client from the computers, re-installing and re-provisioning the clients.
    There should not be any issues with Windows 7 as far as I know, but just be aware that Windows 10 is preferred due to it being the most up to date Windows version.
  8. vizualpro
    Jul 9, 2016
    81
    13
    I've uninstalled the client from the workstation, installed and re-provisioned, issue persists. It appears to happen when the CSA attempts to end the call, but has also happened in the middle of calls so there doesn't seem to be a consistency to it at this point. It certainly a new thing since the latest update though.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Try removing the antivirus from on of the affected machines and try again. Also check that your Microsoft Visual C++ Redistributables are in order.
  10. vizualpro
    Jul 9, 2016
    81
    13
    I will check those today. We began to notice on Saturday that it occurs during a call and when the mouse passes over the app when in IP mode.
    UPDATE: Redistributables are current - app continues to hang even with Sophos anti-virus disabled. As I was ghosting a user as a call came in from queue. User answered the call and it was connected but the timer on softphone never started counting. Two minutes into the call user tried to interact with the app by maximizing a chat that was open, and then it started hanging. I parked call from queue manager, user restarted the phone, unparked call and was live again, but timer didn't start ticking AGAIN, and then the app froze when they tried to interact with the softphone again and end the call.
    #10 vizualpro, Nov 20, 2017
  11. vizualpro
    Jul 9, 2016
    81
    13
    When a call from queue comes in and is ringing, it shows the name of the queue first, then when answered that goes away and only shows caller ID. With this issue, I notice that the name of the Queue never goes away and the timer never starts.
    Similar issue as above, the timer had never started on a call and when CSA went to put them on hold the app hung. I parked the call, she restarted the phone, and unparked the call and it was acting normal then and the timer started with no hanging afterwards.
  12. vizualpro
    Jul 9, 2016
    81
    13
    This is an ongoing call 3+ minutes in - appears to be a problem when Softphone answers calls from queue.
  13. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Can you send me the contents of your 3CX phone logs in a p.m. so i can take a look? You can find them in folder: C:\Users\username\AppData\Roaming\3CXPhone for Windows\Logs
    You will need to upload them to a web sharing service and send me the download link so i can download them.
  14. vizualpro
    Jul 9, 2016
    81
    13
    Thank you. PM Sent.
  15. samhagerty
    Dec 11, 2013
    Has there been any resolution to this issue?
    We've come into the same issue today when users have updated to 15.5.6989.2. Soft phone appears to work fine, can answer a call, will go off to check query on another application then when re-selecting 3cx from the windows taskbar will hang, freeze and then require you to quit - dropping the call also.
    Thanks,
    Sam.
  16. Stevetritton
    Aug 3, 2017
    14
    Also having the same issue with freezing since update 15.5.6989.2 - In a call centre of 130 agents seeing regular crashes. No pattern so far.
    Steve
  17. vizualpro
    Jul 9, 2016
    81
    13
    @YiannisH_3CX was nice enough to review several event logs, 3CX logs, as well as remote in to try and catch it happening real-time. However it didn't happen when he was on the system, and the logs on one PC had .NET errors, but the others do not. So far there has been no pattern and no solution.
  18. jhonku
    Mar 25, 2016
    24
    5
    Hi, we have same issue with last 3cxphone version (15.5.6354.2). It started to crash last week after update.
    We didn't found anything in logs to explain why this is happening.
  19. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Are you all running the same OS? Are you all running the same antivirus? Lets try to find what there is in common to your installs that will make this easier to troubleshoot.
    Also when the application hangs is the service still running? Can you open the task manager and right click on process so you can create a dump file?
    If so can you please create a dump file while the client i stuck and send it to me in a p.m?
    mixig likes this.
  20. vizualpro
    Jul 9, 2016
    81
    13
    We just had one freeze this morning before I saw this, I will attempt to get that dump file for you asap.
    Also, I'm going to utilize a free tool called Belarc Advisor which creates a full system report. If somebody else could also do this on their client PCs so that we can more easily locate the similarities. https://www.belarc.com/products_belarc_advisor
    UPDATE: Dump File and Advisor report sent in PM
    #20 vizualpro, Dec 6, 2017
