Windows to Linux
Discussion in 'Windows' started by data37, Nov 14, 2016.
  1. data37
    Apr 7, 2015
    15
    Can we take a Windows backup and restore it onto a Linux machine?
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hey there
    Yes of course you can take a backup from Windows and restore on Linux ;)
  3. Z32x2
    Dec 7, 2016
    Can you specify from which lowest Windows version I can jump to Linux?
    Is it possible to create backup from v12.0.41311.996 SP6.2 and import to Linux v15 (debian ISO, own wildcard cert) ?
    I'm asking because when trying to upgrade version-by-version (on copy of production machine) there is warrning about trunk in v14 that I should delete and recreate it using wizard (DK / Uni-tel) which imply recreating inbound rules etc...
    Regards
    Z32x2
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hi there,
    Going from v12 to V15 is not possible i am afraid. i would recommend going to V14 like you did make the appropriate changes, convert your call history there and then move to V15.
