Windows Update + 503 No matching transport found/INVITE from local
Discussion in '3CX Phone System - General' started by neon013, Nov 12, 2015.
  1. neon013
    Dec 16, 2013
    A couple of days ago our 3CX phone system worked fine. We have several buildings connected over VPN and hence several extensions at different locations - and all worked OK both for external and internal calls. Over the evening I allowed some 30+ updates to take place on our Windows 2008 server. I am guessing that from one of these updates our 3CX system was affected in the following way:-
    No external or internal calls can be made to the site which has the server, although the server serves all sites. At the moment I have had to redirect all external calls to another site to receive the call.
    On reviewing the logs (see below - example is an internal call from extension 111 (Home) to extension 191 (location of server) :-
    12-Nov-2015 11:58:52.356 Leg L:99.1[Extn] is terminated: Cause: BYE from PBX
    12-Nov-2015 11:58:52.305 Leg L:99.2[Extn] is terminated: Cause: 503 No matching transport found/INVITE from local
    12-Nov-2015 11:58:52.302 [CM503020]: Call(C:99): Normal call termination. Call originator: Extn:111. Reason: Server Failure
    12-Nov-2015 11:58:52.302 L:99.1[Extn] failed to reach Extn:191, reason Server Failure
    12-Nov-2015 11:58:52.302 Call to T:Extn:191@[Dev:sip:191@192.168.19.12:5060] from L:99.1[Extn] failed, cause: Cause: 503 No matching transport found/INVITE from local
    12-Nov-2015 11:58:52.302 [CM503003]: Call(C:99): Call to <sip:191@leapfrog-merlin:5060> has failed; Cause: 503 No matching transport found/INVITE from local
    12-Nov-2015 11:58:52.252 [CM503025]: Call(C:99): Calling T:Extn:191@[Dev:sip:191@192.168.19.12:5060] for L:99.1[Extn]
    12-Nov-2015 11:58:52.203 [CM503027]: Call(C:99): From: Extn:111 ("HomeDottty" <sip:111@leapfrog-merlin:5060>) to T:Extn:191@[Dev:sip:191@192.168.19.12:5060]
    12-Nov-2015 11:58:52.203 [CM503004]: Call(C:99): Route 1: from L:99.1[Extn] to T:Extn:191@[Dev:sip:191@192.168.19.12:5060]
    12-Nov-2015 11:58:52.201 [CM503001]: Call(C:99): Incoming call from Extn:111 to sip:191@leapfrog-merlin:5060
    Additionally when trying to reproduce the problem and get the above log – it worked for a few calls only! - Log below is 25 minutes earlier but I have no idea why it worked for a short time period.
    12-Nov-2015 11:33:07.467 Leg L:80.1[Extn] is terminated: Cause: BYE from 192.168.1.12:5060
    12-Nov-2015 11:32:52.774 [CM503007]: Call(C:80): Extn:113 has joined, contact <sip:113@192.168.1.12:5060>
    12-Nov-2015 11:32:52.772 L:80.2[Extn] has joined to L:80.1[Extn]
    12-Nov-2015 11:32:50.134 [CM503025]: Call(C:80): Calling T:Extn:191@[Dev:sip:191@192.168.19.12:5060] for L:80.1[Extn]
    12-Nov-2015 11:32:50.087 [CM503027]: Call(C:80): From: Extn:113 ("HomeNeil" <sip:113@leapfrog-merlin:5060>) to T:Extn:191@[Dev:sip:191@192.168.19.12:5060]
    12-Nov-2015 11:32:50.086 [CM503004]: Call(C:80): Route 1: from L:80.1[Extn] to T:Extn:191@[Dev:sip:191@192.168.19.12:5060]
    12-Nov-2015 11:32:50.084 [CM503001]: Call(C:80): Incoming call from Extn:113 to <sip:191@leapfrog-merlin:5060>
    Please advise if you have any ideas – is the Windows Update a red herring?
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    please open a ticket on our Support portal and provide us the logs of the Phone System in order to check them and find what is causing the termination of the call.
