Windows Vista + Voip Client 7.0.4526.0
Discussion in 'Windows' started by chrisneal, Jan 20, 2009.
  1. chrisneal
    Nov 20, 2008
    27
    I have tried to get the VOIP Client v7 to work on Vista w/SP1. If I login it shows I'm "On Hook" (3CX never shows the station registered) If I try to dial an extension or anything.. As soon as I touch a key 3CX Voip Client I get a "3CXCoipClient.exe has stopped working" Close Program window... Any ideas?
    I've tried unstinstalling and resinstalling with v6 client... No success
  2. chrisneal
    Nov 20, 2008
    27
    Loaded VOIP Softphone BETA.. (Noted in the annoucement at the top of this forum..) WOrks fine.. Dials, Receives Audio, etc....
    Any ideas?
