Windows XP and Apache
Discussion in '3CX Phone System - General' started by PowrrrPlay, Jan 11, 2008.
  1. PowrrrPlay
    Jan 11, 2008
    Hello
    I already have a Windows XP server set up with Apache in a production enviornment. It is a quad xeon server with plenty of CPU horse power to add the 3CX SIP server. I have read the installation manual.
    I am worried that if I install 3CX it will damage my current copy of Apache 2.x.x. I understand that once I get 3CX installed I can set up the 3CX as a virtual host, I just do not want to go through the 3CX install portion that includes the apache server install.
    Help/suggestions?
  2. simones181170
    Dec 4, 2007
    51
    in my server i've sugar crm with apache web server and i've installed 3cx and i've no problem
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    FIRST AT ALL NOBUDDY CAN GIVE YOU A WARANTY WHAT WILL HAPPEN
    but perhaps you solve this with a backup or you can clone the server and try it on the clone ?
    Andy
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i suggest for getting info from a offical you have to edit the Subject
    Andy
  5. simones181170
    Dec 4, 2007
    51
    after bed experience with software
    i've made a test server where i can try all the new
  6. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Why don't you consider virtualising the server? At the cost of an O/S license it'd stop you worrying about this sort of thing.
  7. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    I agree with Pentagle -
    Why don't you set up a VM and keep it for 3CX only? That way you can leave the production setup untouched.
    Alternatively you can also install 3CX on the production machine you have - 3CX's Apache is not installed in the common Apache folder location. So you will not have any trouble with your current Apache service you already have running.
    rgds
  8. PowrrrPlay
    Jan 11, 2008
    nickybrg;
    I have confirmed your remarks and now have the free edition installed and operating with all green lights on a private LAN. The 3CX documentation is weak on the operational set up. Now that 3CX is installed I can review the set up and test some internal lines. Can close this discussion.
