windows7 ultimae IIS not abyss
Discussion in '3CX Phone System - General' started by jmooo, May 12, 2015.
  1. jmooo
    Mar 11, 2015
    18
    How do I configure 3cx phone server version 12 to use my IIS install NOT abyss on a windows 7 ultimate os?
    I installed IIS first, then ran the 3cx installer. Found the choice of webservers "grayed out".
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please note that IIS can't be used by 3CX Phone System on windows workstations but only on windows servers. That is why the option is grayed out on installer even if you installed IIS.
    This is because of restrictions in number of active connections on these environments, while Abyss doesn't have such restrictions.
