Windstream/Paetec VoIP Provider
Discussion in '3CX Phone System - General' started by alloch70, Mar 13, 2013.
  1. alloch70
    Jul 8, 2009
    13
    I wanted to see if anyone is using Windstream/Paetec as their provider w/3CX? I have been unsuccessful in getting a call in or out with the following message:
    Call or Registration to 16782642732@(Ln.10005@Windstream) has failed. [ V4 10.250.0.5:5060 UDP target domain=unspecified mFlowKey=824 ] replied: 604 Does not exist anywhere; from IP:10.250.0.5:5060
    Any ideas or help would be greatly appreciated.
    Thanks,
    Allen
  2. LonelyDrone
    Mar 20, 2013
    a 604 is typically an issue with the remote party ID in the SIP invite. Not sure if there is a way to turn that off in 3cx. Try that and let me know.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    No problem at all with Windstream Paetec
