wireshark equivalent for an adsl router ?
Discussion in '3CX Phone System - General' started by regfixit, Dec 18, 2008.
  1. regfixit
    Mar 7, 2008
    35
    I am trying to diagnose problem with external extension and wondering if there is a way to trace packets that the router sends to the internet. The external extenstion is a Thomson 780WL ADSL router with built in VOIP so there is no firewall or STUN stuff to configure.
    When external extension makes a call I use wireshark on the 3cx server host to see what happens:
    receive INVITE from external extension
    reply with status 407 -proxy auth required
    receive ACK
    receive INVITE with Cseq 2 and proxy authorisation stuff
    send status 100 trying, 180 ringing
    send status 200 OK with session descriptor
    then 3cx repeatedly sends the status 200OK until after 30 sec it disconnects the call with a BYE and a note that no ACK was received.
    If I look on the external extension router system log I see
    VOIP send INVITE
    VOIP recv 407 proxy auth required
    VOIP send ACK
    VOIP Send INVITE
    VOIP recv 100
    VOIP recv 180
    Voip recv 200 OK
    VOIP send ACK
    So the extension is telling me it sent an ACK, but it does not arrive at 3cx. The audio is working fine in both directions until the call is cut by 3cx because it didn't receive the final ACK.
    What is puzzling me is that the first ACK is received no problem.
    So what I want to do is analyse the packets coming out of the external extension to see what desintaion is used on the final ACK - but I can't use wireshark as this is all internal to the router.
    The router has telnet interface and various commands like ip debug traceconfig plus snmp - is there a way to make it foward its packets to the LAN or dump them to a log file or something like that ?
    Alterhativel anyone have an idea why the first ACK makes it OK, but the second ACK gets lost ?
  2. regfixit
    Mar 7, 2008
    35
    Update: Just "for fun", I changed the 3cx SIP port in the General settings to 5061 instead of 5060. After doing this and updating external extension to register to 5061 it all works fine and the final ACK is now received.
    So all working, but still interested to know if anyone can explain why and also original Q about how to trace packets that are going straight out of the router.
  3. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    So you sistuation is
    3cx server ------- NAT router ------ internet ------ thomson with problems ???
    Probably there is somekind of SIP awarenes in the NAT router and that will recieve the ACK and doesnt send this to 3cx.
    edit: in the partner forum there is a whole discussion about 3cx and external extensions, the only 2 relyable options are: hardware VPN or Tunnel, the rest is trial and error.
  4. regfixit
    Mar 7, 2008
    35
    OK thanks for that. I did have hardware VPN setup, but wanted to avoid rtp stream for calls via voip provider having to be routed by 3cx so wanted to make the extension external again.
    Ie. external extension places call via voiptalk - I want voiptalk to send rtp stream direct to external extension and not to my 3cx to forward down vpn to "internal" extension.
    Will keep trying...
    I also read in RFC3263 that the ACK to a 200 response is passed straight to the transport stream so it kind of explains why even though I get the ACK for the 407 auth req'd I don't get the 200 ACK.
  5. Powermage
    Mar 19, 2008
    103
    I dont know for sure, but when you disable all the PBX delivers audio (on handset and on the voip lines) .
    Will the RTP traffic still go through the 3cx or will the handset make a new route to the sip provider through his local internet connection? at least with internal phones it will because we have 2 branch offices and without an VPN from branch to branch we didnt get voip audio between the phones.
  6. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    Since this router is VoIP-aware/capable, it is very likely that it monopolizes port 5060 for itself. So this could explain why changing to another port resolves the issue.
    Regards
    Kevin
