Wireshark in V15.5
Discussion in 'Ideas' started by AlexDBarrett, Aug 22, 2017.
  1. AlexDBarrett
    Jan 25, 2011
    71
    9
    Great addition.
    Would it be possible to have a constant trace creating a file of a preset time period or files size.
    This may be done for an on premise install quite easily but a little more difficult in a Cloud environment.
  2. tvdir
    Feb 17, 2017
    66
    15
    You can also configure a span port on your switch and connnect a PC running Wireshark to that port. This does not put extra load on the PBX.
  3. AlexDBarrett
    Jan 25, 2011
    71
    9
    Yes this would work well if your own installation.
    If it were a clients it would be a little more difficult.
