wishlist: make the field with the number to dial editable
Discussion in 'Windows' started by flurk, Sep 13, 2010.
  1. flurk
    Sep 4, 2010
    19
    i'm struck by some user-unfriendly aspects of the voip softphone.
    The field with the telephone number to dial has some wierd behaviour and is missing essential editing functionality.
    - yes, you can paste telephone numbers into the field (luckily! you don't have to type all the numbers by hand!)
    but then:
    - one cannot (e.g.) type by hand a prefix and then paste in a number after that prefix
    - once a number is pasted, one cannot move left and right with the left arrow and right arrow buttons within that text field. Worse: the left and right buttons call up the main menu and the last called menu. This is so sh***ty. A totally unexpected behaviour.
    - one cannot insert or delete digits inside the number field.
    PLEASE make that number field a regular windows editable text field (e.g.: if you doubleclick on the number field it turns into an editable textbox, or if you rightclick on it you would get a menu: "edit / insert / cut / copy / paste / delete / undo / escape".
    If you rightclick on the telephone number now, one gets the main menu. Totally unexpected! This is not according to the general Windows conventions.
    thank you
    regards,
    Flurk,
    Bruxxels
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    You will have better luck posting feature requests in the new website for it at http://3cx.ideascale.com
