Within Management Console, see Extensions Actively Ringing/InCall -
Discussion in 'Ideas' started by kinetix, Mar 19, 2018.
Within Management Console, see Extensions Actively Ringing/InCall - 5 5 3votes
5/5, 3 votes
  1. kinetix
    Jan 7, 2010
    26
    This used to be part of the Console, but with V15, it was no longer able to be done. THis was always a great tool for testing - it offered a quick look at "Active Calls" BUT, included Active Extensions and/or Ringing Extensions.
