wits A81-E android 2.2 tablet no sound both side
Discussion in 'Android' started by tjsam, Oct 7, 2010.
  1. tjsam
    Oct 7, 2010
    hi guys i install 3cx phone apps from android market and configured with my sip account. Once my account activate i make test call to my mobile number, the phone is ringing but i don't hear any dial tone, after answer the call both side cannot hear anything it's two way audio problem can anyone help me with this issue... :cry:
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,475
    94
    It would be best to disabled any active firewalls on your routers.
  3. tjsam
    Oct 7, 2010
    thanks for the replay LeonidasG, i am not using any firewall in my modem or router....any other suggestion
  4. marccopolo
    Sep 5, 2010
    go into audio setting and put play and record buffer to -1 and mic gain to 1 goodluck
  5. LeonidasG
    Nov 19, 2008
    1,475
    94
    The settings you mentioned should be there by default.
    Only if you've tampered with them before should you need to change them back to their default values.
    Let us know if this actually fixes your sound issue, although it sounds more of a Firewall issue.
