Working directory
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, May 5, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I remember a thread a while back about getting the working directory. By default if I write a file to a .dll it writes to the inetsrv directory. But the working directory variable that you guys have added is always blank, so how is that supposed to populate?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Shahzad,
    That feature has been added in the latest build released (3559), and requires 3CX Phone System version 8.0.10824 to get that variable filled (http://www.3cx.com/blog/vad-change-log/).
    Are you running an older 3CX version?
    Regards,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I am running v8.0.10116.583
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What I did for now to find the working directory, is I first found the system shared application data folder, and then did a scan for the name of the .dll file.
  5. VAD_Support
    Aug 6, 2009
    690
    A quick fix for you: unzip the file attached, and replace those files in %ProgramData%\3CX\Data\Http\Interface\ivr
    With that new version of the files, you will see the working directory variable with the right value.
    Regards,
