Working with Prompts
Discussion in '3CX Phone System - General' started by ramonbatista, Apr 28, 2010.
  1. ramonbatista
    Mar 29, 2010
    7
    I have in my 3CX System two prompts (English & Spanish).
    How can I do something like that :
    "Hi, wellcom to X Company. Press 1 to continue in English. Press 2 to continue in Spanish"
    And when Press 1, then the user only use the English Prompts, or if the user press 2, then he/she will be using the Spanish Prompts.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    At this time it is not possible, kindly post a feature request in the feature request section of the forums.
  3. skagen
    Mar 30, 2010
    35
    you can set up another digital receptionist and have the same prompts, only in spanish. On the first, or main receptionist, you can have the message say "1 for english, 2 for spanish" and just have option 2 point to the second receptionist.
    Let me know if this will work for you.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    I believe he was referring to use actual 3CX prompts in another language. Could you clarify as to make sure I have provided you with the correct information.
