Works in Version 3 but not Version 5 (NAT)
Discussion in '3CX Phone System - General' started by waggy, Apr 21, 2008.
  1. waggy
    Nov 26, 2007
    I have a system running fine in version 3, backed it up, and installed at a different location under version 5.1
    If my phone (Snom 320) is running behind a natted router (external) then if I connect to V3 I can hear the other party. If I reconnect to the V5.1 then the other party can;t be heard. However - if I point the DMZ to the Snom 320 it works ok.
    It works fine internally.
    Any help very very gratefully received...
    Logs attached
    Version 5.1
    12:53:44.000 Call::Terminate :[CM503008]: Call(47): Call is terminated
    12:53:43.968 Call::Terminate :[CM503008]: Call(47): Call is terminated
    12:53:34.984 CallCtrl::eek:nLegConnected :[CM503007]: Call(47): Device joined: sip:10008@192.168.0.240:5060
    12:53:34.421 CallCtrl::eek:nLegConnected :[CM503007]: Call(47): Device joined: sip:100@192.168.1.20:2059;line=gv8x1x75
    12:53:30.671 Line::printEndpointInfo :[CM505002]: Gateway:[sn4114] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.252:5060]
    12:53:30.453 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(47): Calling: VoIPline:10001@[Dev:sip:7181045@sip.voipon.co.uk:5060]
    12:53:30.437 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(47): Calling: PSTNline:10008@[Dev:sip:10008@192.168.0.240:5060, Dev:sip:10009@192.168.0.240:5060, Dev:sip:10010@192.168.0.240:5060, Dev:sip:10007@192.168.0.240:5060]
    12:53:30.390 CallCtrl::eek:nIncomingCall :[CM503001]: Call(47): Incoming call from Ext.100 to [sip:901491636393@sip.douglascontrols.co.uk;user=phone]
    12:49:40.015 Call::Terminate :[CM503008]: Call(46): Call is terminated
    12:49:39.984 Call::Terminate :[CM503008]: Call(46): Call is terminated
    12:48:58.609 CallCtrl::eek:nLegConnected :[CM503007]: Call(46): Device joined: sip:10008@192.168.0.240:5060
    12:48:58.593 CallCtrl::eek:nLegConnected :[CM503007]: Call(46): Device joined: sip:100@192.168.1.20:2059;line=gv8x1x75
    12:48:54.843 Line::printEndpointInfo :[CM505002]: Gateway:[sn4114] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.252:5060]
    12:48:54.703 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(46): Calling: VoIPline:10001@[Dev:sip:7181045@sip.voipon.co.uk:5060]
    12:48:54.671 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(46): Calling: PSTNline:10008@[Dev:sip:10008@192.168.0.240:5060, Dev:sip:10009@192.168.0.240:5060, Dev:sip:10010@192.168.0.240:5060, Dev:sip:10007@192.168.0.240:5060]
    12:48:54.609 CallCtrl::eek:nIncomingCall :[CM503001]: Call(46): Incoming call from Ext.100 to [sip:901491636393@sip.douglascontrols.co.uk;user=phone]
    Version 3
    13:05:58.343 StratLink::eek:nHangUp [CM104001] Call(337): Ext.100 hung up call; cause: BYE; from IP:80.229.0.16
    13:05:43.125 CallLegImpl::eek:nConnected [CM103001] Call(337): Created audio channel for Ln:10001@voipon (217.14.132.172:15936) with Media Server (217.207.4.181:9452)
    13:05:43.093 StratInOut::eek:nConnected [CM104005] Call(337): Setup completed for call from Ext.100 to Ln:10001@voipon
    13:05:43.093 CallLegImpl::eek:nConnected [CM103001] Call(337): Created audio channel for Ext.100 (80.229.0.16:64448) with Media Server (217.207.4.181:9450)
    13:05:36.421 CallConf::eek:nProvisional [CM103003] Call(337): Ln:10001@voipon is ringing
    13:05:30.796 CallConf::eek:nIncoming [CM103002] Call(337): Incoming call from 100 (Ext.100) to sip:901491636393@meddis.liveluggage.com
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    Did you run the firewall checker and did it pass the test?
    If not please review manual and ensure static port mappings....
