WOW - Thanks but Message Waiting Indicator
Discussion in '3CX Phone System - General' started by keith.bucknall, Feb 22, 2007.
  1. keith.bucknall
    Feb 22, 2007
    38
    Guys,
    I have been using A@H and Trixbox for a while in a very small office setup with the Cisco 7940's on 8.2 Sip firmware.
    I have not decided to test 3cx and - wow - this is great thanks for all the hard work and keep it up. I would be interested to know about future releases and details of your Roadmap for the different version - also to start working as a partner to offer this to our clients.
    BUT....
    In the meantime do you support the MWI_STATUS or message waiting indicator feature on these devices and if so what configuration is needed.
    Regards
    Keith Bucknall
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Hi Keith,
    We're going to support RFC 3842 for MWI. If your devices do support of this standard - than it will work. This standard will be implemented pretty soon, probably it even appear in next public version. But right now we have a lot of tasks with higher priority.
  3. keith.bucknall
    Feb 22, 2007
    38
    Archie
    thanks for letting me know, as long as i know it is on the roadmap - not a problem.
    thanks for a great product.
