Wrapping the call control api with asp.net restful api
Discussion in 'CRM / Helpdesk / App Integration' started by AdamW, Feb 21, 2017.
  1. AdamW
    Feb 21, 2017
    Hi I'm having difficulties at the moment wrapping the call control api into an asp.net api.
    When I run the console app on the 3cx server it runs fine, when I try to access the call control api from an asp.net application I get an error stating that the configserver is not connected on the GetDN() call. Is it possible to access the call control api from a web application?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,597
    125
    Yes, but you need to set the connection information before you use the API, that is server, port, user name and password. You read that information from the 3CXPhoneSystem.ini file, just as the sample does.
    Regards.
