Write to File / SQL / Shell Scripts
Discussion in 'Call Flow Designer' started by Josh Dinsdale, Oct 24, 2017.
  1. Josh Dinsdale
    Oct 11, 2017
    11
    Hi Guys
    Firstly, I am using 3CX debian version.
    In preparation for our move away from Askozia to 3CX i am currently trying to rewrite a custom app i wrote in Askozias Call Flow Editor in 3CX's CFD.
    The old system uses a txt file to store a variable, the call flow overwrites that file when it is accessed, which updates the contents to the new variable.
    My plan was to replicated this with the Read / Write file function. I dont want to append the file, but overwrite it each time and am trying to do this by changing the 'Open Mode' to 'CreateNew'. However this seems to write the file once (if it doesnt already exist), but then doesnt seem to over write it after that.
    I have permissions correctly setup (i've actually set them to 777 for testing).
    Any ideas on that?
    My next approach was to think oh hell, lets rewrite this properly using SQL, but then i discovered that MySQL isnt supported, only PostGres or MSSQL. We have a MySQL infrastructure setup that i would like to have used, but I guess it looks like that idea is out of the window?
    Also, are you planning to build in any functionality to run shell scripts on debian installs? I probably could have uses this as another mechanism to make it work..?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hello @Josh Dinsdale,
    In first place, please take a look at the following article explaining how to troubleshoot CFD apps issues:
    https://www.3cx.com/docs/manual/cfd-troubleshooting/
    Regarding the file override issue, I think that the problem is that you're using the "CreateNew" mode, which will only create the file if it doesn't exist, otherwise an IOException is thrown, as explained here:
    https://msdn.microsoft.com/en-us/library/system.io.filemode(v=vs.110).aspx
    For sure the 3CXQueueManager.log file will have the exception described above.
    What you need to use is the mode "Create", as explained in the same article above.
    RE MySQL, unfortunately it is not supported. However, you can use a Launch External Script component to run your own C# .NET Core code, and from there you can connect to MySQL and run your query. But in this case you will not be using the Database Access component.
    And regarding running shell scripts, that's also something that you can do using the Launch External Script component. You just need to call "Process.Start", for example as explained here:
    https://loune.net/2017/06/running-shell-bash-commands-in-net-core/
    Hope the information helps.
    Kind regards.
    Josh Dinsdale likes this.
  3. Josh Dinsdale
    Oct 11, 2017
    11
    Thanks edossantos, changing to 'create' did the trick! :)
