Wrong CallerID
Discussion in 'Android' started by dab, Jun 20, 2010.
  1. dab
    dab
    Nov 1, 2009
    67
    3CXPhone runs almost fine on HTC Desire (Android 2.1) registered to 3CX V8 over 3G.
    But if a call arrives it just display it's own extension, in my case "41" instead of the remote extension or CID.
    Have others the same issue or is it possible that I've a configuration error?
  2. dab
    dab
    Nov 1, 2009
    67
    Sorry for pushing up,
    am I the only one that has this problem?
    Can someone please confirm that it works fine in his environment?
    Thanks in advance.
  3. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Same problem here.
  4. fas
    fas
    Mar 9, 2009
    5
    Same problem here (on Samsung I9000) ... rest works good. Does someone know a solution?
  5. gauvins
    Jun 30, 2010
    7
    CID shouldn't have anything to do with your client (app). I use 3CX and sipDroid on a variety of services. On some peers you can get a CID restricted to your registered DID, on some you get random CIDs (the local termination), on some you can assign a custom CID.
  6. fas
    fas
    Mar 9, 2009
    5
    Sorry, but in this case it makes no sense! I've got about 6 extensons in one ring-group. My 3CX-Anroid-Client as well. On all "normal" SIP phone (the other 5 extension) I can see the caller-ID except on the android client ... I can not beleive that this should not be a android client bug ;)
