Wrong display of tables on Edge
Discussion in '3CX Phone System - General' started by Sopock, Jan 21, 2016.
  1. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Hi!
    Maybe somebody can confirm that, for example, service status is displayed under service name?
    Thanks.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    For which version?
    I can confirm when using V14 with Edge, that a number of the screens have a different appearance than what other browsers will show. When I look at the Services with Edge, it shows the status first and then the service name. When looking at the same with others, to include IE11, they show service name first and then the status.
    I think that 3CX prefers a compliant browser such as Chrome as this is also supportive of WebRTC.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Yes, exact version v14.0.47020.408 could be selectable from login screen :idea:
