Wrong java version error
Discussion in '3CX Phone System - General' started by dalilama, Jun 29, 2009.
  1. dalilama
    Jun 29, 2009
    When I try to install the skype gateway it tells me is can't as the JRE version is less than 1.5
    But when i run java -version from the dos prompt it tells me the version is 1.50_15
    George
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,533
    71
    Hi, George
    George, the gateway you refer is the old version one, Java-based, we just released a completely rewritten version, 2.0, not Java-based, much improved compared to this one. My advice is to uninstall the one you have and to install this new one, even in Beta. Please check this:
    http://www.3cx.com/forums/3cx-gateway-for-skype-releases-10511.html#p53886
    Any feedback will be welcomed.
    Regards
    vali
