Wrong label for static IP button
Discussion in '3CX Phone System - General' started by Sopock, Jul 12, 2016.
  1. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Hi!
    There is repeated text under Network Settings. :S
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    What do you mean by repeated text?
    Can you tell me exactly where this is or what does it say?
    Thank you for reporting
  3. CBUTLER
    May 11, 2015
    52
  4. YiannisH_3CX
    May 10, 2016
    5,425
    352
    I believe that is by design but thank you for reporting. I will point this out to the R&D department and they can take it from there
  5. CBUTLER
    May 11, 2015
    52
    I don't know how it could be argued that it is by design. There are two radio buttons under that menu which determine the type of external IP config. Either Static, or Dynamic, thus each radio button should be labeled accordingly. For example: http://screencast.com/t/NvGnM1KiN
  6. nb
    nb Support Team
    Jun 7, 2007
    2,110
    143
    Thanks for reporting.. It is a translation issue. We will address it in the next update.
