Wrong SDP in TLS calls
Discussion in '3CX Phone System - General' started by dig1234, Jul 16, 2017.
  1. dig1234
    Jun 1, 2015
    75
    3cx v15.5.5 sends the local IP in SDP for TLS calls even if the client is not on same LAN. This was a bug in early v14 versions that was corrected but seems to have crept back in.
    Thanks.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    hello dig1234,
    Kindly note that there a non any issue with the SDP for TLS calls even if the client is not on same LAN. Please make sure that the phones are on the supported firmware and use the default template. Also the TLS settings are placed on the web interface of the phone. Please ensure that the settings for TLS on the phones are corrected and let us know.
