Wrong Tone Inbound Fax
Discussion in '3CX Phone System - General' started by zman574, Jul 27, 2010.
  1. zman574
    Jun 24, 2010
    57
    Hopefully someone can point me in the right direction here. I have had everyone looking at my fax issue to see why I simply can not connect to my fax. I dont really know what to think. When I call my fax number from my cell phone the tone sounds like a fax machine trying to send not receive a fax. Two very different tones.
    I would like to compare this fax sound with someone else that has a fax working on voip and 3cx, could someone please provide me with a fax number that is working so I can just call it and test it out by ear?
    If you would like to listen to what my sounds like the number is 1-603-546-7132
    jim
  2. zman574
    Jun 24, 2010
    57
    if nothing else could someone post a working fax log so I could compare what is happening to mine compared to yours.
    jim
  3. zman574
    Jun 24, 2010
    57
    Also has anyone had any trouble with windows fax service sending the wrong tones or not working correctly. The system is installed on a windows 7 platform.
    Jim
  4. zman574
    Jun 24, 2010
    57
    Unfortuantly after nearly 70 hours of working with this fax issue I have decided to go with a different fax set up using ringcentral. It was fairly easy and as long as you have their tech support (which is awful) change the sip port for the fax device to one you are not using with 3cx and then set up a static ip address for their device and forward the port that you set up to point to the device the fax can be set up with ease.
    I would love to hear from someone that has a fax line working so I can copy the setting they have since both 3cx and 888voipstore were unable to accomplish getting the fax to work.
  5. leejor
    10,368
    229
    I tried it, and yes it's an interrupted tone, not the solid modem type/fax tone you would expect when calling in. I take it this is an analogue fax machine? Odd behaviour. Did it do this if plugged into a PSTN phone jack and called?
