X Button to delete extensions dangerous
Discussion in '3CX Phone System - General' started by TSlocum, Jul 14, 2016.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    In the new extension list, there is an X button on the right side to delete extensions. If you click this, the extension is instantly and irreversibly deleted without warning. This is a useless and dangerous feature. There already is a delete button on the top, which requires you to first select an extension and then press delete, negating accidental clicks.
    3CX should remove the X next to every extension, and I also think it would be a good idea to add a confirmation ("Are you sure you want to delete these extensions?") to the regular delete button.
  2. ucs1
    Jun 21, 2013
    42
    How about the button to delete trunks without confirmation. Had a client delete 7 of their trunks yesterday ... only option is to roll out the backup. There is no Undo and doesn't prompt for confirmation
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Thanks for the feedback - we are going to make a confirmation dialog. "Are you sure? ..."
    For now just be careful.
  4. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Thanks, mate! I still think the X button is entirely redundant anyway because of the delete button on the top, but a confirmation is definitely better than nothing.
  5. Jayrome
    Oct 7, 2016
    Thumb up for this confirmation dialog box.
    Deleted accidentaly an extension, and had to recreate it.
  6. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello TSlocum ,
    We have implemented this feature in V15 SP2.
    There is going to be a confirmation dialog,
    Thank you for your feedback !
  7. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Exquisite; thank you!
  8. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    You can update, thanks
  9. Ben C
    Oct 14, 2014
    71
    I just updated today and tested both the X on the right side of the extension and the 'Delete' button. The extension is deleted right away without asking...
    Is it only me ?
    PBX 15.0.59381.0
  10. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Clear the cache please and try again....
  11. Ben C
    Oct 14, 2014
    71
    Yes, you are right, after clearing the cache, I got the confirmation window.
    Thank you MichaelB
  12. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    You are welcome, in the next update you will not require to clear/refresh page.
    This will be handled in SP3.
