X-Lite one way Voice
Discussion in '3CX Phone System - General' started by todd, Jul 2, 2007.
  1. todd
    Jun 9, 2007
    35
    3CX Phone System Version3.0.2328.0 (Free Version)
    Extension 8007
    Extension is external
    Bind to Media Server
    X-Lite V3.0
    Extension 8000
    Extension is Internal
    SPA2000
    When make call from 8007 to 8000, just 8000 can hear voice from 8007. No voice from 8007 to 8000.
    But, If I change X-Lite V3.0 to a SPA200 them working fine. OR when I setup a Internal extension use X-Lite, it work fine. So, I think my server setup is good but only X-Lite V3.0 for Extension is external with some problem. Or maybe the ports problem?
    Any suggestions for this? Thanks!!!
    21:02:45.625 StratLink::eek:nHangUp [CM104001] Call(22): Ext.8000 hung up call; cause: BYE; from IP:192.168.1.103
    21:02:28.328 CallLegImpl::eek:nConnected [CM103001] Call(22): Created audio channel for Ext.8000 (192.168.1.103:16480) with Media Server (192.168.1.2:7054)
    21:02:28.328 StratInOut::eek:nConnected [CM104005] Call(22): Setup completed for call from Ext.8007 to Ext.8000
    21:02:28.328 CallLegImpl::eek:nConnected [CM103001] Call(22): Created audio channel for Ext.8007 (192.168.0.103:50582) with Media Server (60.241.xxx.xxx:9016)
    21:02:26.937 CallConf::eek:nProvisional [CM103003] Call(22): Ext.8000 is ringing
    21:02:26.843 CallConf::eek:nIncoming [CM103002] Call(22): Incoming call from 8007 (Ext.8007) to sip:8000@60.241.xxx.xxx:5060
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Address specified by external extension 80007 is not global. Configure X-lite (external) to "Discover Global Address".
  3. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    123
    try adding a stun server to the xlite account.
    that solved my audio problems with xlite.
  4. todd
    Jun 9, 2007
    35
    working now!!!Thanks!!!
    I set a stun server to the xlite account.
    23:32:47.906 StratLink::eek:nHangUp [CM104001] Call(36): Ext.8000 hung up call; cause: BYE; from IP:192.168.1.103
    23:32:39.359 CallLegImpl::eek:nConnected [CM103001] Call(36): Created audio channel for Ext.8007 (218.215.xxx.51:59329) with Media Server (60.241.xxx.xxx:9040)
    23:32:39.343 StratInOut::eek:nConnected [CM104005] Call(36): Setup completed for call from Ext.8000 to Ext.8007
    23:32:39.343 CallLegImpl::eek:nConnected [CM103001] Call(36): Created audio channel for Ext.8000 (192.168.1.103:16406) with Media Server (192.168.1.2:7080)
    23:32:37.890 CallConf::eek:nProvisional [CM103003] Call(36): Ext.8007 is ringing
    23:32:36.859 CallConf::eek:nIncoming [CM103002] Call(36): Incoming call from 8000 (Ext.8000) to sip:8007@192.168.1.2
  5. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    123
    cool mate glad i could help out
  6. ksantella
    Apr 23, 2007
    23
    same issue
    cant seem to get the external xlite to give audio in both directions.
    I can connect and resolve to my pbx from xlite (external). I hear audio on my laptop but not inbound to my sip phone inside.
    I have tried with and without the stun server with same results. The xlite is on a sprint broadband cellular card no router.
    any ideas?
  7. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    123
    and the router on the server side?
  8. ksantella
    Apr 23, 2007
    23
    router on server
    port forwards on router. PBX attached as well as Linksys 942's to this router.
    1 VOIP-TFTP 69 69 192.168.1.2
    2 VOIP-SIP 5060 5061 192.168.1.2
    3 VOIP-RTP 8000 9998 192.168.1.2
    4 PBX 5480 5482 192.168.1.2
    5 VOIP-STUN 3478 3478 192.168.1.2
    6 VOIP-INTERNAL 7000 7500 192.168.1.2
    7 VOIP_VOICE 10000 20000 192.168.1.2
  9. Anonymous
    Anonymous Guest
    You also need 9000 - 9003
    Is you XLite configured as an extension?
  10. ksantella
    Apr 23, 2007
    23
    xlite extension
    It is set up as an external extension (201) and I do have ports 9000-9003 open. If you look at the previous post you will see ports 8000-9998 open.
    all comm works fine with normal inbound calling. It is only when the extension is outside of the pbx that the audio is not being transmitted in the one direction.
