XeloQ Error 407 - Proxy Authentication Required
Discussion in '3CX Phone System - General' started by chwebb1, Jan 30, 2011.
  1. chwebb1
    Aug 16, 2010
    20
    I am unable to make any calls using a VoIP provider called XeloQ, which is supported by 3CX. When I try to make an outbound call on that trunk, I get an error message (407- Proxy Authentication Required) in the 3cx log. Does anyone know how to fix this?
    Thanks.
  2. xeloq
    May 20, 2009
