xlite\eyebeam Presence
Discussion in '3CX Phone System - General' started by mattweeks, Jul 13, 2007.
  1. mattweeks
    Jul 13, 2007
    has 3cx developed a presence for xlite\eyebeam yet?
    I have read reports on xlite being used with 3cx successfully.
    are they only using xlite 2 or 3 if they have used 3 are all of the options available?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    yes it works fine with X lite 3. and i don't think it will take much of your time to check it yourself.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Any of those softphones configure very eaily. Just point then to your 3CX server, enter your extension # and password and that should be it.
