XML Integration with FileMaker Pro
Discussion in 'CRM / Helpdesk / App Integration' started by Mark Geerdes, Feb 19, 2018.
  1. Mark Geerdes
    Jan 29, 2018
    I'm working on integrating with a custom app created in FileMaker Pro using the XML file. I would like some help with the authentication step.
    FileMaker requires the header:
    Content-Type "application/json”.
    and a JSON payload via POST of the following variables:
    [ "user" ;
    [ "password" ;
    [ "layout" ;
    Here is the XML I"m using with edits to hide the actual data:
    <Crm Name="CentralCommand" Version="1">
    <Number Prefix="Off"/>
    <Connection MaxConcurrentRequests="1"/>
    <Parameters />
    <Authentication Type="Scenario">
    <Value>FMToken</Value>
    </Authentication>
    <Scenarios>
    <Scenario id="FMToken">
    <Request Url="https://fm.URL" RequestType="POST" Message="{&quot;user&quot;:&quot;userName&quot;,&quot;password&quot;:&quot;Password&quot;,&quot;layout&quot;:&quot;Client3cx&quot;}" ResponseType="Json"/>
    <Rules />
    <Variables>
    <Variable Name="token">token</Variable>
    </Variables>
    <Outputs>
    <Output Type="HeaderName" Value="FM-Data-token"/>
    <Output Type="HeaderValue" Value="[token]"/>
    </Outputs>
    </Scenario>
    <Scenario>
    <Request Url="https://fm.URL" RequestType="POST" Message="{&quot;query&quot;:[{&quot;cPhone3cx&quot;: &quot;[Number]&quot;}] }" ResponseType="Json"/>
    <Rules />
    <Variables>
    <Variable Name="FirstName">data[0].fieldData.NameF</Variable>
    <Variable Name="LastName">data[0].fieldData.NameL</Variable>
    <Variable Name="Email">data[0].fieldData.Email</Variable>
    <Variable Name="ClientID">data[0].fieldData.CLIENT::__ID</Variable>
    <Variable Name="PhoneMobile">data[0].fieldData.PhoneMobile</Variable>
    <Variable Name="PhoneBusiness">data[0].fieldData.PhoneWork</Variable>
    <Variable Name="CompanyName">data[0].fieldData.CLIENT::ClientName</Variable>
    </Variables>
    <Outputs AllowEmpty="False">
    <Output Type="FirstName" Value="[FirstName]" />
    <Output Type="LastName" Value="[LastName]" />
    <Output Type="Email" Value="" />
    <Output Type="PhoneMobile" Value="[PhoneMobile]" />
    <Output Type="PhoneBusiness" Value="[PhoneBusiness]" />
    <Output Type="CompanyName" Value="[CompanyName]" />
    <Output Type="ContactURL" Value="FMP://fm.URL]" />
    </Outputs>
    </Scenario>
    </Scenarios>
    </Crm>
    Here's the log that I got when testing
    2018/02/17 07:21:00.343|31310|0003|Trc|Request starting HTTP/1.0 GET [URL='http://tbd3cx.mn.3cx.us/api/CrmList/test?num=61228882626&ext=%3CExt%3E']http://domainName/api/CrmList/test?num=61228882626&ext=%3CExt%3E[/URL]
    2018/02/17 07:21:00.346|31310|0003|Trc|AuthenticationScheme: Cookies was successfully authenticated.
    2018/02/17 07:21:00.347|31310|0003|Trc|AuthenticationScheme: Cookies was successfully authenticated.
    2018/02/17 07:21:00.349|31310|0003|Trc|Webclient was not authenticated. Failure message: No principal.
    2018/02/17 07:21:00.349|31310|0003|Trc|Authorization was successful for user: voipadmin.
    2018/02/17 07:21:00.350|31310|0003|Trc|Authorization was successful for user: voipadmin.
    2018/02/17 07:21:00.351|31310|0003|Trc|Executing action method ManagementConsoleJS.Controllers.CrmListController.Test (ManagementConsoleJS) with arguments (61228882626, <Ext>) - ModelState is Valid
    2018/02/17 07:21:00.352|31310|0003|Trc|Executing ObjectResult, writing value Microsoft.AspNetCore.Mvc.ControllerContext.
    2018/02/17 07:21:00.352|31310|0003|Trc|Executed action ManagementConsoleJS.Controllers.CrmListController.Test (ManagementConsoleJS) in 5.5961ms
    2018/02/17 07:21:00.352|31310|0003|Trc|Request finished in 9.6472ms 204
    2018/02/17 07:28:33.841|31310|0014|Trc|Request starting HTTP/1.0 GET [URL='http://tbd3cx.mn.3cx.us/api/CrmList/test?num=6122802760&ext=%3CExt%3E']http://domainName/api/CrmList/test?num=6122802760&ext=%3CExt%3E[/URL]
    2018/02/17 07:28:33.853|31310|0014|Trc|AuthenticationScheme: Cookies signed out.
    2018/02/17 07:28:33.854|31310|0014|Trc|Request finished in 12.9816ms 401
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hello @Mark Geerdes,
    The server side engine currently doesn't support sending requests with Content-Type "application/json”, just checked it and it's only sending "application/x-www-form-urlencoded" when you set the Post Values for the request. But when you use the Message property, no Content-Type is sent with the request.
    We'll improve this in the upcoming updates of 3CX...
    Kind regards.
  3. edossantos
    Jun 27, 2007
    1,080
    77
    However, if the server doesn't check the Content-Type and assumes that it is JSON, then it should work.
  4. edossantos
    Jun 27, 2007
    1,080
    77
    Can you explain the authentication precedure in more detail? Is it OAuth2? The authentication based on a scenario assumes that it is OAuth2, and will follow that authentication flow. If you need something different, then maybe you need a different approach...
    What does the authentication server return? A Bearer to use in upcoming requests? Can you elaborate a bit on this?
