XML Returning from code component. A '<' character cannot b
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Mar 17, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    This is from the ivr error log
    messageXML parsing error in file VadTools_SMS_MF_runSMS_DoIt.aspx, line 18: A '<' character cannot be used in
    attribute 'expr', except through &lt;
    There is an XML string being returned from an external code component.
    How can I accept the string properly?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    This seems to be a bug in the VAD. We're going to investigate it and fix it.
    Meanwhile, try returning the XML escaping invalid characters. Can you do that? Are you able to change the code executed by the External Code Component?
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Yes, I could change the code. For now I just extracted one of the values from the XML to return instead, but I'll try changing the characters also.
  4. VAD_Support
    Aug 6, 2009
    690
    Hi Shahzad,
    Thanks for reporting the error. We're going to fix it in the next release.
    Regards,
