XP VS 2003
Discussion in '3CX Phone System - General' started by galal202, Jun 26, 2008.
  1. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello
    what is better to use Windows XP or Windows Server 2003
  2. darrellchapman
    Nov 26, 2007
    268
    I use Server 2003 but that was because I thought I had to (long story). My personal opinion is that server 2003 is probably a little more stable but XP is still pretty stable. It probably doesn't matter and considering the different in cost (~$650 USD), Windows XP would be preferable.
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Thank you for reply
    No problem in cost because we have both
    so what is your sugest
  4. darrellchapman
    Nov 26, 2007
    268
    I'd go with XP and reserve that license of 2003 Server for something that requires .
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    For 3CX What is the deferent
  6. darrellchapman
    Nov 26, 2007
    268
    None. Use either.
  7. francesco
    francesco New Member
    Jun 23, 2008
    102
    i use Win XP and it is very good.
    no problem.
  8. alsoft
    Jun 27, 2008
    35
    If you have a server 2003 use it! Server 2003 is more stable than xp. Windows Server is more supported by Microsoft about security issues.
    XP works fine but occasionally I need to reboot it.
