Yaelink T41P Provision Template
Discussion in '3CX Phone System - General' started by ETAU, Jul 20, 2015.
  1. ETAU
    Feb 4, 2014
    17
    Hi - I have two settings that I would like to change on the YealinkT4x.ph for a T41P. I have gone through the template a few times and cannot see where I can change these two settings:
    1. Change the Yealink screen saver time. Every 10 seconds the screen flashes Yealink. I would like to either change or disable this.
    2. I would like to force the transport for one phone (modified template) to use TCP for transport in the accounts page properties. Is there a way for force TCP as opposed to UDP in the template?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,249
    202
    Can answer question 1 , disable logo
    Search for phone_setting.lcd_logo.mode , and change it to 0
    For question 2, not totally sure
    Search for,
    #Configure the transport type; 0-UDP (default), 1-TCP, 2-TLS, 3-DNS SRV;
    account.1.transport =
  3. ETAU
    Feb 4, 2014
    17
    First one solved. Thank you.
    I have searched for UDP and transport. When searching for UDP I see a few results, but related to nat keep alive. When I search for the word "transport" the only reference is the last line of the below text. I tried changing this to 1 before, but whatever it did, it didn't change the transport protocol.
    account.1.failback_mode = 0
    account.1.failback_timeout = 3600
    account.1.hoteling.auto_login_enable = 0
    account.1.hoteling.enable = 0
    account.1.hoteling.password = 0
    account.1.hoteling.user_id = 0
    account.1.transport = 0
