yeaklink vp-2009p
Discussion in '3CX Phone System - General' started by webactive, Apr 10, 2011.
  1. webactive
    Apr 10, 2011
    Can anyone advise if yealink vp2009 video phone is supported by 3cx?
    And how easy is it to setup?
    http://www.yealink.com/index.php/Products/detail/id/12
    Many thanks matt
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Most SIP based VOIP handsets can be configured to work with 3CX and register on the PBX.
    You may want to have a look at this webinar from Kerry Garrison at 888voipstore.com
    http://www.voipstore.com/configuring-the-yealink-vp-2009-with-3cx/
    It goes over how to setup the handset to work with 3CX.
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Yes this phone works with 3CX but at the moment plug and play provisioning doesn't work with these models. More then likely you will have to manually setup extension details via the web browser.
