Solved Yealink 3CX Logo - can't disable on V15
Discussion in '3CX Phone System - General' started by Peter Richardson, May 8, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    230
    9
    Hi all,
    I am using Yealink T21P E2 and Yealink T41P phones. I am trying to disable the 3CX logo from flashing on the screen of the Yealinks. I have found this setting in the web interface of the phones, but if I reboot the phone, the setting is overridden by the provisioning from 3CX.
    I have had a look in 3CX under Settings -> Templates, but two problems remain:
    1) I can't edit the template from the 3CX web interface
    2) I don't know which template (exactly) that each phone uses as they are not clearly identified. I could assume the T41P uses the "yealinkT4x.ph.xml" template, but what about the T21P E2?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,822
    564
  3. Peter Richardson
    Apr 6, 2017
    230
    9
    Hey @YiannisH_3CX
    Thanks very much for your help, that was easy! Perhaps it could be made a little more intuitive on the PBX interface?
    myuniquename likes this.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    or replace the 3cx logo in the provisioning folder.
    Tim Steinhoff and AH2 like this.
