yealink 3cx logo
Discussion in '3CX Phone System - General' started by mixig, Aug 24, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    which line I must comment to disable 3cx logo for yealink t22 and t28 on the screen?
    [ Logo ]
    path = /tmp/download.cfg
    {IF model=Yealink-T28}
    server_address = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/logo/yealinkt28.dob
    {ELSE}
    server_address = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/logo/yealinkt22.dob
    {ENDIF}
    all lines or just "server_address......" ?
    thanks
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Normally I would suggest all the lines wihin the logo section. However, commenting the lines will not remove the logo, but only keep the phone from reloading this or a new logo. You will need to do one of the following:
    1, Create a new logo (even if blank) and let the phone grab this from now on,
    or,
    1. Comment out the lines as you have suggested
    2. Manually go to the phone web interface and change the logo setting to none.
    From this point, any new or re-provisioning will no longer try and apply any logo setting.
    I suppose their is likely a template setting that might indicate "set to none", but I have not tried to look that up as the above does the same as well.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    I've found there are various lines scattered in the template for logo. Look around for the same named logo file. Easiest would be to copy the template to notepad and do a find.
  4. ccomley
    Apr 6, 2011
    92
    I'm trying to get rid of this too - if the logo was displayed as well as the menu (etc) it would be fine but clearing the clock/menu display to show the logo is just annoying the customers and they're now giving me a hard time.
    Setting logo to "none" in teh phone config is over-ridden when the phone next configs.
    The template section I've found (below) shows how to select a file to upload, but I've yet to find out how it turns it back on. Perhaps loading a logo causes the logo display to be turned on intrinsically. I shall try just removing this section. If anyone's seen a separate on/off parameter, please comment...
    [ Logo ]
    {ELSE}
    {ENDIF}
  5. ccomley
    Apr 6, 2011
    92
    Aha!
    The 3CX templates are undocumented but YAY for Yealink, who HAVE documented the parameters the phone will listen for. In their section showing how to upload a custom logo, you find
    LCD_Logo = 2
    and, later on, it explains that "2" is for "custom logo" and "0" is for No Logo.
    Of to edit the live templates...
  6. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    thanks guys, i will also try with LCD_Logo=0, i aslo found that information in offical manual for yealink :oops:
  7. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    Before upgrade to v11 i put LCD_Logo=0, created a backup and restore that backup on v11, there is no any logo on yealink T22, it seems that this is working....
  8. craigreilly
    Feb 1, 2012
    3,321
    252
    http://yealink.com/SupportDownloadfiles_detail.aspx?CateId=182&flag=142 has a document for converting a provisioning template for the T38
    Also see here for T28 documentation: http://yealink.com/SupportDownloadfiles_detail.aspx?CateId=184&flag=142
    The UK site might be helpful as well: http://yealink.co.uk/technical-instructions/
  9. Dhaval
    Aug 17, 2017
    14
    does anyone know where I can find documentation of templates on Yealink phones? I can't find it on Yealink website and 3CX won't say what to do.
  10. ITWizardFail
    Jul 18, 2017
    I would do yourself a favor to save quite a bit of time and copy the template to a note document. You already know the part of the filename you are looking to remove: Config:yealinktXX.dob AND %%PROVLINKLOCAL%%/logo/yealinktXX.dob
    If you have a screensaver, you might want to change the line
    screensaver.type = 1 to
    screensaver.type = 0
    You want to make sure you remove from both sections otherwise the logo will linger and pop-up when you are not expecting. For me personally I went to the extent of removing from every Yealink model as I use the template for every customer we deploy phone systems too.
