Yealink/3CXapp - DHCP renewals
Discussion in 'Windows' started by 3CXusername, Mar 24, 2016.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    When our Yealink T46G/T48G get a new IP 3CXapp reloads and asks the user to select phone with the old and new IPs.
    Using 2x Windows 2008 DNS.
    Any recommendations to prevent this (outside of static IPs on phone)?
    thanks in advance
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    I think what you are asking is not possible.
    You have to use static IP on the phone.
  3. Bunce
    Sep 19, 2012
    19
    You could extend your DHCP lease time to mitigate this somewhat.
    I can't think of a reason to have a short lease time, and this will reduce the incidence of picking up a new IP due to power outages or similar.
    Ideally 3CX should identify its the same phone using the MAC address, but at worse, there must be some type of expiry against each phone registration entry..
