Yealink -- 486 Busy Here messages
Discussion in '3CX Phone System - General' started by snowsam, Jul 19, 2011.
  1. snowsam
    May 26, 2011
    79
    We are about 15 days into our new phone system setup, using a Patton 4960 with a PRI and 3CX 10 and Yealink phones. So far, the transition has been quite positive.
    At times, one of the alert emails that 3cx sends me is:
    This seems to happen when you call someone else and there is a standard busy signal on the other end pf the phone.
    Instead of playing you the standard busy, you are shown the "486 Busy Here" message on your phone. Is this normal for 3cx/patton? Or is there something that can be configured to give a standard response to the user?
    Thanks,
    Sam
    Here is the debug from 3CX:
    and here is the debug from the patton:
    edit: title updated
  2. willow
    willow Member
    Mar 1, 2011
    471
    Re: Patton 4960 PRI -- 486 Busy Here messages
    This is probably how the phone is programmed to handle this message, I would suggest logging into the web portal of the phone and checking and seeing if there is a setting that can change this behavior.
  3. snowsam
    May 26, 2011
    79
    I don't think it is the phone, since I am getting the first "3CX Phone System Email Notification" email straight from 3CX. I think it is something about how the Patton and 3CX talk each other and deal with this busy condition.
    Anyone else seen this?
  4. Raf Wenger
    Apr 5, 2010
    23
    I am experiencing the same problem, our Yealink T22 phones displaying a 'Busy Here' error message instead of playing a busy tune when calling a busy phone.
    3CX is emailing the error right away.
    I could not find anything on the Yealink web GUI to modify this behaviour.
    We're using a VOIP provider, so no Patton gateway for us, but same problem.
    Anyone?
  5. snowsam
    May 26, 2011
    79
    OK, I changed the posting title to reflect that we now think this is a yealink issue and not an issue coming from the Patton side.
    Anyone have any more ideas?
    We are using Yealink T22P, 26P, 28P phones with the most recent (Jun.23 2011) firmwares.
    My biggest challenge in troubleshooting the problem is finding a phone number that I can call that will give me a busy signal every time!!
  6. snowsam
    May 26, 2011
    79
    I've gotten confirmation from 3CX support that the "486 busy here" messages are normal.
    In order to no longer receive the alert email every time someone dials, go to the following path:
    3CX Phone System > Settings > Advanced > Custom Parameters
    Search for RESPONSE_ERROR_CODES and remove the 486 from the Value field.
    I hope that helps other people!
