Yealink Attended transfer
Discussion in '3CX Phone System - General' started by jgdeltra, Aug 19, 2010.
  1. jgdeltra
    Jun 7, 2010
    I am using 3cx version 9. I use Yealink, 3cx softphone and Cisco phones. Everything works fine except "Attended/Announced" transfers when the transfer is from Yealink to Yealink phones. The yealink model is SIP-T22P. This happens all the time when the "attended" transfer is from a Yealink to another Yealink phone.
    FYI, "Blind" transfers work fine in all cases. "Attended/Announced" transfers work fine when the transfer is to a non-Yealink phone such as Cisco or 3cx softphone.
    I have attached 3cx server logs. One is of the Yealink to Yealink "attended" transfer which does not work. The other is a Yealink to 3cx softphone transfer which works fine.
    I followed http://www.3cx.com/sip-phones/Yealink-IP-phone.html and Yealink "Configuration Guide for Yealink IP Phone & 3cx" instructions.
  2. fury75
    Aug 17, 2010
    The "Semi-attend transfer" in Yealink configuration is disabled?
  3. jgdeltra
    Jun 7, 2010
    I am using a Patton Smartnode to interface Analog lines. I upgraded to the latest version and it fixed the problem.
