Yealink BLF and Blind transfer
Discussion in '3CX Phone System - General' started by mirjam.nz, Aug 5, 2011.
  1. mirjam.nz
    Dec 6, 2010
    28
    Blind transfers with Yealink T26p phones is only possible if one enteres the extension manually.
    If a blind transfer is made via a BLF key, the original call disconnects instead of being transferred through to its destination.
    The same Blind transfer works just fine with Cisco or Snom phones.
    Does anybody have a resolution for this Blind Transfer Problem with Yealink BLF?
    FYI, an announced transfer works just phone using the BLF keys.
    Firmware on Yealink T26p: 6.60.0.120
    3CX version: V10 SP2
    Cheers
    Mirjam
  2. willow
    willow Member
    Mar 1, 2011
    471
    Re: Yealink T26p and BLF Blind transfer
    have you tried it with the 60.110 firmware. the .120 is a little buggy.
  3. mirjam.nz
    Dec 6, 2010
    28
    Hi Jeremy
    Yes, we did, the same behavior. I can reproduce this fault on different 3CX servers.
    I really hope there is a solution for this.
    Can you perform a Blind Transfer with the BLF button ?
    Cheers
    Mirjam
  4. mirjam.nz
    Dec 6, 2010
    28
    Found a solution to our problem, change the setting on the Yealink phone to:
    Disable the option Semi-Attend Transfer in the menu Phone/Features/Enable Semi-Attend Transfer
    Cheers
    Mirjam
