Solved Yealink BLF Not Working
Discussion in '3CX Phone System - General' started by Rod Bacon, Feb 3, 2017.
  1. Rod Bacon
    Dec 22, 2016
    14
    Hello. We are trialling 3CX at the moment, with a view to deployment later this year. I'm running V15 and am testing several models of Yealink Phones (T42/46/68), which are running the latest 3CX-released firmware in each case (there is a newer version on the Yealink site, but that breaks things horribly), as per below;
    SIP-T46G - 28.80.0.130
    SIP-T42G - 29.80.0.130
    SIP-T48G - 35.80.0.130
    I'm running a slightly modified template (to fix timezone problem) based off the latest original template.
    No matter what I do, I can't get the BLF LED's to work on the handsets. Status in the softphone is perfect, so I know that all notifications are working correctly at the PBX level, but not on the handsets.
    Does anyone have any ideas as to what I should be checking, please?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
  3. Rod Bacon
    Dec 22, 2016
    14
    Thanks. I can't believe I missed that!
