Yealink BLF's not working?
Discussion in '3CX Phone System - General' started by seanbts, Oct 19, 2010.
  1. seanbts
    Oct 12, 2010
    34
    HI All,
    Installed T28P and T20P phones but cant get the BLF to light up, when I press the BLF button for extension 10, it calls that extension but the LED is off all the time, tearing my hair out trying to get it working!! Any one any suggestions?
  2. 888Mike
    Apr 27, 2009
    11
    Have you tried updating to the newest version of the firmware, it should fix your issues.
    Please read this post on the 888VoipStore Free Technical Support forum. ( http://www.888voipstore.com/forum/yealink/450-yealink-voip-phone-firmware-version-v50.html )
    Click here to visit our Free Technical Support Forums for other 3CX and Yealink related issues.
  3. daviscomputing
    Apr 22, 2008
    20
    Under the Account tab, go down to "Advanced" and open it up. Go to "Subscribe Register" and Enable it and then click "Confirm". Mine lit up after doing this.
  4. No-body
    Aug 19, 2010
    13
    Beside that, make sure you activated your license, in evaluation mode, the BLF's don't work.
