yealink call transfer
Discussion in '3CX Phone System - General' started by mixig, May 18, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    is it possible to make call transfer to another extension and if that extension is busy that call is return back to me again? By default when call transfer is done i hang up nad that is it, but if another side is busy call is droped..
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    I read the manual again, everything is working normally...
  3. Chalky
    Apr 20, 2012
    11
    Take a look at this article:
    http://www.3cx.com/blog/voip-howto/blind-attended-transfer-yealink/
    You'll want to do an attended transfer and then you'll be able to hear the line is busy yourself and then reclaim the call.
