Yealink DECT W52P
Discussion in '3CX Phone System - General' started by Arturo, Jan 9, 2018.
  1. Arturo
    Jan 4, 2018
    20
    I would want to buy a W52P but i don't see this model in the provisioning list where i must add a telephone and it's compatible with 3CX.
    #1 Arturo, Jan 9, 2018
  2. tvdir
    Feb 17, 2017
    66
    15
    It is supported, you should add it under FXS/DECT.
    Arturo likes this.
  3. Arturo
    Jan 4, 2018
    20
    ok, thanks
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Arturo likes this.
