YeaLink Expansion Module DSS Keys
Discussion in '3CX Phone System - General' started by quayfour, Aug 30, 2011.
  1. quayfour
    Dec 1, 2009
    12
    When transferring a call using DSS keys set up on the expansion module - Blind Transfer calls are alwars dropped.
    Escorted transfers work ok
    Any ideas
  2. willow
    willow Member
    Mar 1, 2011
    471
    make sure that semi assisted transfers are disabled. and blind transfers are enabled on the phone under phone>features.
  3. countrycomp
    Dec 2, 2008
    53
    Hi Willow,
    Can you confirm that you have actually done Blind Transfers on Yealink phone DSS buttons with 3CX?
    If you have, what configuration do you use (apart from the little bit you posted) and what keystrokes do you use?
    Dave P.
  4. willow
    willow Member
    Mar 1, 2011
    471
    I press transfer (either the softkey or hard key), then the BLF key, then either transfer again or hangup.
