Yealink Firmware 81.0.61
Discussion in '3CX Phone System - General' started by 3CXusername, Apr 12, 2017.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Support,
    I saw it was released the other day. I can not locate any release notes. Could you provide a link?
    thanks
  2. saqqara16
    Jan 13, 2016
    46
    7
    Downloaded the update, believe it has some to do with uaCSTA technology that is required for ver 15.5 CTI / IP Phone control
  3. 3CXusername
    Jul 31, 2014
    183
    16
    Most likely but would like specifics.
  4. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,610
    243
    You would want to post on the Yealink forums as it is a Yealink firmware release.
  5. 3CXusername
    Jul 31, 2014
    183
    16
    I may try them as there seems to be no answer here. The .60/.61 appears to be custom 3CX as there is no mention on any Yealink documentation I found.
