Yealink Firmware Unsupported
Discussion in '3CX Clients' started by kconnor, Jun 10, 2017.
  1. kconnor
    Jun 8, 2017
    Hi Guys,
    I just upgrade a system to 15.5. Previous to doing that I upgraded all the Yealink -t42g phones to the latest firmware. After the install was complete I am being told that the firmware version is unsupported. I tried to dropping it back to version 29.81.0.60 and it too is saying it is unsupported. I cannot find the 29.81.0.61 version that it is saying is supported. Can anyone help? I need this done before Monday.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Did you tey going to the phones tab, selecting said phones and clicking upgrade firmware? (Even though it would be a downgrade)
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    And really unless u find a bug it's not the end of the world running the latest Yealink firmware.
  4. Tony Cave
    Jun 8, 2017
    28
    Having the same issue with a Yealink T46G running 35.81.0.90 firmware, In addition, this phone reboots when in voicemail and the VM then shows its still connected in the active calls list.this then stays connected until I manually shut it down in the active call list !
  5. kconnor
    Jun 8, 2017
    It won't let me run the upgrade because although it says unsupported it says it's up to date. I did try installing a lower version and then running the update. I says completed successfully but does nothing.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Please note that the management console cannot downgrade a phone running a higher firmware than the supported one. You can only upgrade a phone.
    @kconnor
    Are your phones provisioned as local or remote? Are you using a 3CX FQDN or your own? Also are you using an internal FQDN or are you using an IP? What is included in the provisioning link under extension settings / phone provisioning?
    Note that firmware downloaded from the management console is stored in folder
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxxxx\firmware_new\yealink for windows and
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/xxxxxxxxxxx/firmware_new/yealink for linux
