Yealink - missed calls no CID
Discussion in '3CX Phone System - General' started by TOBI144, Nov 14, 2011.
  1. TOBI144
    Nov 14, 2011
    7
    we are using 3CX v9 SP 5 and Yealink T28 and we have the following problem: Wenn we miss a call in the directory is just our own DN not the external number of the caller?
    Has anyone an idea for this problem?
    Thanks!
    10,368
    228
    So...when a call is ringing on the phone, you do see the external callers number?
  3. TOBI144
    Nov 14, 2011
    7
    Yes I do! During a call I see the caller number.
  4. leejor
    10,368
    228
    Is too much information being sent, for each call, for the phone to retain in it's missed call memory? Perhaps it being truncated.
  5. TOBI144
    Nov 14, 2011
    7
    But how can I limit the sended information for each call?
  6. leejor
    10,368
    228
    Do you use a gateway or VoIP provider (which provider)? Some gateways can be set-up to send additional information. Do you have 3CX set up to send the name of the ringgroup to the sets?
  7. TOBI144
    Nov 14, 2011
    7
    We use INDODE Vienna as VoIP-provider. I do not send the ringgroup names to the sets!
  8. leejor
    10,368
    228
    Could there be a local directory on the set that is being used to compare (and display) the number?
  9. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Take OUT the DID name in the inbound rule (however this can still tack on the ring group name)....
    Or go get Grandstream phones ;-)
  10. TOBI144
    Nov 14, 2011
    7
    . . . the solution was the DID name in the inbound rules!
    THX!
  11. sigma1
    Nov 20, 2009
    542
    Glad that was it.
